Overlapping text
I am working with another engineer.  When I open his sheets there are problems with text overlapping one another. If it were screen size I would think that it would still print out ok, but it does not. It prints the sheets with the overlapping print.   Is there a way to fix this.
What version of Mathcad are each of you using?
Can you attach an example worksheet?  (click "use advanced editor," then "attach")
sleamer1-VisitorAuthor
We are both using Mathcad 15. I know at the bottom - the table is blowing up - I don't know how to stop that - but there is no reason why it is doing that at the top.
Can you provide the same sheet printed from his computer for comparison?
I guess that the problem is about Microsoft Excel version. Which version have each one of you?
Best regards.
Alvaro.
23-Emerald I
In Mathcad 15, you can edit/select all, then format/separate regions.
Unfortunately that will almost certainly destroy a lot of formatting.
There is also the possibility ( more work) of changing the styles (text and variable) to smaller fonts.
This usually happens if the sheet was created using a different zoom factor than 100 %.
If this sheet is then open with zoom 100%, the text regions for some reason are erroneously formatted a tiny bit too narrow and so you experience a line break in the text region, resulting in the text region possibly overlapping other regions.
Its quite tedious to have to regrip every text region border an make it a liitle wider so the text again fits in just one line.
I don't know of any help other than using zoom factor 100% only when creating the sheet.
The problem with the Excel table overlapping (underlapping?) the other regions seems to be a different effect, though. Not sure but perhaps a font problem?
Werner
Yeah, Werner - I think you are right. When I change the zoom to 125 it reads much better, but it does not fix it for printing. Also the table is still blown up. I down size it by dragging but that is kind of a pain.
Its a very old bug through many versions of Mathcad and the only "solution" is to keep zoom always at 100% when you edit/save .
Repairing an already "infected" sheet would mean to manually readjust the right border of every text region at zoom level 100%. which is a lot of tedious work for larger sheets. Not sure if the problem with the table is related to the text region problem but I guess - no.
-MFra-
Since via software, there is little you can do to eliminate this MAthcad defect, ..... a way to proceed to restore everything as in the original file, is to make a print of the original worksheet on the computer where It was created. Then, reopening the file on another computer, proceed with the reorganization,following the previously made printing.
We have seen this same issue.  The windows 7 display settings has three options for display size.  [Smaller - 100% & Medium - 125%(default) & Larger - 150%]  Try putting it on the 100% option that worked for our issues.  It may have something to do with the setting the creator of the file had and you may need to match their setting.
The problem is not the display size setting in Windows but the chosen zoom factor within Windows 15.
23-Emerald V
...within Mathcad 15...
{Microsoft's policy at the moment is to never create windows 15...}
Sharon,
Read my comment and make a suggestion for a fix, under product ideas.
MGM
I have the same problem. did you solve it? if yes please send me the solution.
Abraham
