Page numbering
  • January 29, 2014
  • 7499 views
Am I missing something, or are page numbers not able to be offset by the user in PRIME (e.g. start numbering at '4' instead of default '1')? I typically use Mathcad as a support to other reports and need to pre-number the pages when combinnig the report (e.g putting together multiple Adobe files that are pre-numbered).
Text editing needs to include the ability to use sub- and super- scripts.
Is there a plan to allow labeling of plots without resorting to manually inserting text-blocks?
I understand changing solution schemes and equation formulations ... but I need to be able to easily create quality reports and text editing and plotting are important aspects. Otherwise I could just use EXCEL ...
I fear you are not missing something.
Wish this and the other things you mentioned would be the only features missing, but ...
Prime simply is by far not where PTC marketing wants us to believe it is.
Currently on Prime 3.0 - how long is it going to take is the question?
Mike
BESchmitt1-VisitorAuthor
Ok, another nit ... the key board 'Page up' and 'Page Down' does not function correctly. It is moving the cursor and if the cursor lands in a text region then the page up/down STOPS in the text region (at the text top or bottom of the text). I have to manually move the cursor into the work space to continue paging up/down.
How can you be at v3.0 and not have basic editing features debugged?
