Parameter calculation with odesolve and minerr function
  • July 9, 2012
  • 25 replies
  • 9895 views
Hello all
I am trying to use the Odesolve and Minerr function in Mathcad to get the parameters of a thermal model, but having problem now.
When using the minerr function, there is an error "this variable is undefined"
I can not figure out where is the problem.
Could anyone please help?
The worksheet is attached.
I am using the mathcad14, and I saved it as mathcad 11.
Hope it can be opened.
Thanks in advance!
23-Emerald V
July 9, 2012
Unfortunately, I am just about to go through the door to work, so can't look in detail. However, if you trace the error back, it says there are too few initial conditions in Function (your function "Function", that is)
Stuart
Hello Stuart,
Thanks very much!
You did give me a hint, the equations should be PDEs.
I will try again with Pdesolve again.
However, I wonder if there are other ways to solve this problem.
At first I tried to fit the the Power to be a function of time, so that the equations has only one variable t, which could make the calculation simple. Unfortunately, my experimental data is is not enough. With polynomial regression, the output function P(t) varies significantly from theory and the final output value(C1,C2,R) of the minerr function is not correct. I am not sure if it is caused by the uncorrect P(t). Will this solution work if enough data are abtained with another experiment? Will the P(t) have an impact on the integral of T1(t)?
Thanks for your help!
Like this?
Alan
Improved worksheet attached.
Hello Alan,
Thanks for your reply.
I have tried with your method and the output is not correct.
Please see my attachment above.
I am not sure if it is cause by the insufficient experimental data.
Will not the P(t) have an impact on the integral of T1(t)?
Thanks!
It's not surprising that the results of your worksheet are way out, as your polynomial fit to power is totally unrepresentative of the measured powers.
Have you looked at the modified worksheet I supplied (I edited my original reply to provide a more sensible sheet)?
Thanks!
Yes, it will, and the model incorporates this.
Alan
Looks like either the final value of power or that of temperature is wrong (or at least, not consistent with your model).
Alan
Perhaps you should have recorded more values of power between the last two values you currently have recorded. See attached.
Alan
