phase shift
- 11 replies
- 6032 views
- Translate All
Hello Everybody,
Could you please help me with this problem.
In the attached worksheet, there is function sp(k,b), where k is the variable and "b" is the parameters. for different set of parameters, there is a phase shift between sp(k,c1) and sp(k,c2).
How can I find the amount of the phase shift? or minimize the phase difference?
The ultimate goal is to find a new set of parameters as close as possible to the model parameters "c1"
Thank you very much in advance
