Plot won't evaluate unless a calculated function explictly defined
- April 16, 2012
- 2 replies
- 3841 views
Please see the attached MCAD worksheet.
The function alpha (t) has a variable alpha max that is previously defined. Alpha max carries units with it and those units appear correct. In the sheet I can only get the plot for omega to work by manually setting Alpha max to a value with the correct units (1/s^2).
I cannot figure out why the program is doing this. If anybody can assist that would be greatly appreciated!
Thank you,
Mike
