plotting an abitrary polyhedron
I have MathCad 14.0 and would like to plot a 3-D polyhedral surface from a set of (x,y,z) vertices. I could not find any plotting option/function to this - am I missing something? Does MathCad 15 have this functionality?
There is nothing built-in, but if you download and install this e-book you will have more functions for plotting polyhedra than you know what to do with
http://communities.ptc.com/community/mathcad/mathcad-usage/blog/2010/05/27/creating-amazing-images-with-mathcad-14
I can't have that functionality because a set of vertices does not describe a surface! You would have to provide the information which vertices form an edge and which a tile. Being no 3D CAD software Mathcad's posibilities are limited and a surface is built by quadrilateralso only. But the "Amazing Images" E-Book Richard pointed you to does more most of us where aware that could be done.
In general that is of course true, but are you sure it's true when the surface is specified to be a polyhedron? If the surface is a polyhedron then I think the vertices must be on a 3D convex hull, and that is enough to determine the edges. I may well be wrong about that though, because I certainly do not have any proof
I am not sure, either, but I guess you are assuming that the polyhedron is simply connected and convex, which was not stated by the OP. This does not mean, though, that I would know of a simple way to create the necessary data structure in MC for a convex polyhedron.
