Plotting tri-angles
  • July 2, 2010
  • 16 replies
  • 10203 views
Has anyone got a simple example of plotting tri-angles?
When using trigonometry I find it a little pedantic drawings the shape in Excel and either manually updating the drawing or passing numbers through Mathcad to Excel.
Cheers in advance.
Mike
Best answer by f.kohlhepp
Arre you looking for this?
Yes.
It's that simple I feel stupid asking the question.
Cheers
Mike
Perhaps generalizing the problem will make you feel less stupid
"Has anyone got a simple example of plotting tri-angles ?" [Mike]
Mike,
You will understand why I can't return my supplementary
suggestions on Fred work sheet . Only projects that
have interest and/or in good enough shape will be attended.
The *.zip is not viable for work sheets exchange.
Personal time or company time is not infinite, This added
suggestions "Tri-angle" would have taken almost no time
to repost in Akiva, now I have spent 1hr explaining why
you can't be hepled more than an image, which image
is in fact not needed as it is in the work sheet.
Hope the *.zip is returned to work sheet.
jmG
PTC community is discussion only
but not "Mathcad work sheets collaboration"
Why is the zip file such a problem?
