Polar plot using Excel component
  • October 15, 2010
  • 13 replies
  • 6863 views
Any one has an example of polar plot using excel component.
Or a way for the result of a function be exported to an excel sheet for plotting in excel.
Best answer by AlvaroDíaz
Try attached.
Regards. Alvaro.
I have used a polar plot as a pie diagram in Mathcad-sheet.
See http://twtmas.mpei.ac.ru/mas/worksheets/Basa_Water.mcd
What version of Mathcad and Excel are you using?
Mike
Attached is an example of an Embedded Excel component within M15. This might not work in previous versions.
You could also write data directly to Excel and produce the graph in a separate sheet. I prefer to have the component embedded in the Mathcad worksheet.
Mike
Try attached.
Regards. Alvaro.
Nice example. Your Excel Polar plot only seems to work to display when the component is active though.
Mike
I use windows 98, mathcad 11 and office 2002. If there are some compatibility issue, maybe it could be fixed editing something in the excel with double clikc, and saving the changes. So your particular version for os - office - mathcad can be stored in the file.
Regards. Alvaro.
