Possible to create iterative solve blocks?
- June 6, 2013
- 11 replies
- 5212 views
In the attached MathCAD 14 worksheet I am attempting to solve for the embedment length for multiple sets of variables ( concrete dimensions a,b,ma,mb) using the Given command/block. Is it possible to pass multiple groups of variables in these three equations and solve for the single variable E using the Given block?
For each set of variables only one equation is solvable for E while the other two will not be solveable. The solvable equation changes as the dimensions changes. If the equation is not solvable, is it possible to for MathCAD to return a zero or unsolveable response instead of turning red?
