Possible to find the maximum of a function of functions?
  • May 31, 2013
  • 5 replies
  • 3232 views
In the attached MathCAD 14 worksheet, M(x) is a function of 5 other functions. I'd like MathCAD to tell me what the maximum value of M(x) is. Is there anyway to do this?
Best answer by Werner_E
Find attached one possible way
Werner_E25-Diamond IAnswer
dsochor1-VisitorAuthor
Thank you very much Werner! I wasn't able to get the maximize function to work. I've never seen this iterative method or the lookup command before.
Ooops, using maximize() would be more natural and much easier. See attached. If it didn't work for you, maybe you forgot to provide a guess value.
The function max() I used works for vectors, matrices, scalars and strings, but not for functions. So it was necessary to create vectors for x and function values M(x).
Maximize() sure is the better way to do it.
