Prime 3.0, correct format for NaN?
I am a recent convert from MathCad 15 to Prime 3.0. In the attached Prime 3.0 worksheet, what is the correct formatting for stating if a variable is not an answer (NaN) to set a variable to one value, and if it is an answer to set it to another variable?
Werner_EAnswer
You do it the same way in Prime as you did in Mathcad - you use the built-in boolean function IsNaN(...).
Werner_E25-Diamond IAnswer
dsochor1-VisitorAuthor
As always, thank you Werner.
