Probability brainteaser
There's an interesting probability post over on reddit (jars, balls, choose at random, maximize the odds of choosing something specific). One of the comments is "Someone with the appropriate software can probably plug all this stuff in and get a maximum value." Any takers?
http://www.reddit.com/r/math/comments/qiesr/interesting_question_on_probability_about_sorting/
QUESTION:
You have 3 jars, 20 red balls, 100 blue balls. You need to place all the balls into the jars such that when you blindly pick one ball out of a random jar, you maximize the chances that it will be red. (when picking, you'll first randomly pick a jar, and then randomly pick a ball out of that jar) you can place the balls however you like, but each ball must be in a jar. All balls are identical other than color. Picking will be truly random, so no ingenious strategy will change the mathematical outcome.
1) What is the best to maximize the chances to pick a red ball?
2) What is the probability of picking a red ball in your answer?
