Problem in filling Mathcad sheets
  • February 17, 2010
  • 1431 views
I have a special problem:
When starting to work on an empty sheet, all of the area on the pages does not allow typing and I have to try several locations where I can enter something. After the pages get eventually filled, this problem disappears.
Anybody familiar with this kind of behaviour? This is only for MCad13 and MCad14 versions and does not appear in MCad2001i that I also use sometimes.
Do you have 2001i installed on the same PC as versions 13 and 14? The only versions that were designed to coexist on the same PC were versions 11 and later. Version 2001i might be the cause of the problem.
You could try repairing the installations of versions 13 and 14. Maybe that will fix it.
Richard
