Problem inserting a 3D plot --Help Please!
  • June 7, 2011
  • 11 replies
  • 4311 views
Hi all,
I'm having a strange problem when trying to insert a contour plot or any of the other 3D plots. I only get a small box about 14pts high. I can't resize the box.
This is what the box looks like.
I uninstalled 14 and reinstalled 13 and still get the problem. This has not happened to me before on any version. Any advice will be appreciated!
bryan
Which OS?
Please post a worksheet with the plot inserted.
June 7, 2011
Thanks for responding Richard.
My OS is Windows XP home. I've attached a copy of a sample worksheet. The plot does not even show up unles you drag a box around it...
bryan
That is strange. It's just an empty placeholder. If you type a:23+4 into it and then evaluate a (a=) you get a=27. Do you see the 3D plot I inserted in the attached sheet?
