Problem using variable defined in solve block
- May 10, 2012
- 8 replies
- 4041 views
I am having a problem using a variable after it was defined with a solve block with the find command. It seems like the variable is assigned correctly, but when I try and use it later in the sheet in another solve or find command it gives me an undefined variable error. The error traces back to the assignment on the variable in the original solve block. Please see attached.
