Problem with Graphs in Mathcad 15
  • February 15, 2012
  • 8 replies
  • 3898 views
I recently opened a couple of worksheets in Mathcad 15 that I hadn't used in 4-5 years. They were created in an earlier version. The graph scales in these worksheets contain one or more numbers with a large number of decimals; for instance 0.299999999999 instead of 0.3. The number of these that appear in any particular axis (always the vertical) varies with the number of increments I assign to that axis. I've tried to change the number of digits after the decimal point [Format:Number Format] but nothing changes.
Does anyone know of a fix for this?
Best answer by RichardJ
It's a bug. If you make the y-axis go 0-2, instead of 2-0, no problem. If you switch the axes, then the same problem ocurrs on the x-axis. Right now, I can't see any way to fix it.
Could you post an example worksheet.
I'm afraid I can't figure out how to do that. Is there a way to attache the file? Or do I have to create an image of the worksheet?
You can attach a file by selecting 'Use advanced editor' in the top right corner of the reply box.
Mike
