problem with integration
- 3 replies
- 3140 views
- Translate All
Hi, I would like some advice on a problem I am having with integration using the Evaluate Symbolically command. When I apply this command to equation (9) in the attached file, I get the result of the first integral. However when I apply the command to that result I just get a repeat of the result; I don't get the result given in the article I got the equations from (see equation (10) in the attached file).
Thanks.
