Problems with Inverse laplace and step function
  • October 2, 2010
  • 7 replies
  • 6321 views
I make an calculation of an antenna circuit. For this I have to use the step function. When I want to
make the inverselaplace function to my equation, it will not be work.
I think this will not be work, because I think that matcad will calculate values from t<0. But I want to
analyse only values which are t >= 0.
Can I give mathcad the information, that it calculate only with values t>0
Please look to the matcad file, where I have made also a lot of comments on page 4.
The pages before is normally not relevant for you.
Thanks a lot
Regards
Roger
Best answer by AlvaroDíaz
Please see attached.
Regards. Alvaro.
Regards. Alvaro.
Roschee1-VisitorAuthor
Hello Alvaro,
I have openend your mathcad file and I can see that you have created an graph, but I don't see an curve.
Also the invlaplace
current_1(s):=CURRENT_1(s) invlaplace, s
ist colored in red.
Is it working at your home ?
I use mathcad 14
Regards
Roger
I use mathcad 14
which version of 14?
