PTC Mathcad Matrix to C++ Code
Many companies use Mathcad to test their FORTRAN or C++ codes. Mathcad is part of the verification process for their production codes. Mathcad even lends itself as a documentation tool for these calculations.
The purpose of this worksheet is to take that process one step further. With this worksheet Mathcad content (matrices) can be exported as C++ code. This worksheet could easily be modified to generate FORTRAN code.
This worksheet is set up to dynamically work for any matrix size. It exports the code to a “code.txt” file. Simply open that and cut & paste the contents into your C++ project.
