Read in Excel sheet tags via visual basic
  • September 14, 2011
  • 12 replies
  • 7842 views
Hi all,
is it possible to read in the tags of the sheets in an excel work sheet? I'd like to populate a list box with the tags so that I can choose by clicking which sheet I wish to read in.
Has anybody some VB code that might be useful?
Thanks in advance
Raiko
Best answer by MikeArmstrong
Which script are you getting the error with? Push button or list box?
Mike
Do you mean the name of the worksheet within Excel?
Mike
Raiko17-PeridotAuthor
Hello Mike
yes. The several sheets within one Excel file (i.e. tabs) are labelled sheet 1 to... Quite often I get Excel files with measurement data where these names have been altered (e.g. temp. reading 11...) so that I need to open the excel file in order to get the tab names. Any automation process on this task would help.
Cheers
Raiko
Knew that you'd answer first 😉
This sort of works, have a look.
I cannot find the code to do it fully automated, but this is a work around. I have used the function below within the excel worksheet to extract the tab name, and then called into Mathcad. It would mean whoever creates the Excel file doing a little extra work.
Have a look at both of the attached and let me know what you think.
Mike
