Regression of a trigonometric function or of an exponential function
  • March 16, 2011
  • 10 replies
  • 7090 views
is it possible to do a regression as simple as in a graphing calculator?
There I have got a statistic menu where i can write down my x and y values. Then I hit the [Reg]ression button and the [sin]us button. Done.
I tried to solve my problem in MathCad with 2 vectors and the sinfit function, but it does not work 😕
There is the same problem with an exponential function...
There I used expfit, where it said the "guessing"-vector is optional, so I left it out. -> No solution...
Can u help me??
Thank You.
Best answer by RichardJ
Mathcad's sinfit function is essentially useless. There is no multiplier for x, and that multiplier changes the frequency of the sin wave. Whoever originally implemented this function, with no ability to vary the frequency, must have been mentally deficient!
Here's a generic approach to fitting. You can use this to fit any function, not just the few built-in ones.
Can you post a worksheet of the problem?
Mike
FloFi231-VisitorAuthor
It's a task from my schoolbook.
t is the time in hours
dm is the current flow rate of a tidal power station in (m^3)/h
In the second graph you can see, that the regression results of my graphing calculator ar better than the results of mathcad...
RichardJ19-TanzaniteAnswer
