20-Turquoise
September 28, 2010
Rows_Gathered_Count.
  • September 28, 2010
  • 23 replies
  • 9193 views
With intuition, I need help to write a function (in Mathcad 12) was briefly described as following:
In other words,
Thanks in advance.
-LL-
Best answer by AlvaroDíaz
Some kind of explanation added.
Regards. Alvaro.
Column 1 of the output is the number. Column 3 is the number of occurrences. What's column 2? Sometimes it seems to be the index of the first occurrence, sometimes the index of the second.
lvl10720-TurquoiseAuthor
20-Turquoise
September 29, 2010
Sorry, Richard. I forgot to generalize my question.
-LL-
Loi,
There is no consistency in your answers.
I assume "L" is being called because it sits adjacent to the last time 0.968 occurs - If this is the case why had 0.981 got the letter "F"next to it. Shouldn't it be "O"
Mike
Similar to
http://communities.ptc.com/message/152543
Please check the attached.
Regards. Alvaro.
20-Turquoise
September 29, 2010
It's a neat answer. Thanks a lot. Sorry, I forgot to generalize my question, above.
-LL-
Don't worry. Generalization added. Also use first or last letter in the answer. In your picture, letter for 0.981 is "F" or "O"? Notice that the csort at the end is optional.
Regards. Alvaro.
