Runtime Error
  • January 26, 2011
  • 4842 views
When I try to print from MathCad (14), I get "Unknown runtime error". Then "Mathcad.exe application error. The instruction ....referenced at ...The memory cannot be read." And then the program exits. It only happens when I print to a particular (naturally most convenient) printer. Printing elsewhere or to Adobe pdf works fine. Worksheets are very simple and I have tried several, so it seems specific to the printer not the worksheets. Any suggestions? I did have trouble with MathCad crashing on print preview some time ago, but re-installing and downloading updates solved that problem.
Early releases of Mathcad 14 had serious issues with print preview. Patch 020 seemed to fix most of those. If you don't have that patch it might be worthwhile finding and downloading it.
Print preview works fine (although I did have problems earlier and downloaded the patch), but it is the printing itself (and only to one printer?) that is the problem now.
So I take it this happens with more than one worksheet?
Have you tried re-installing / re-mapping the printer?
Mike
http://communities.ptc.com/servlet/JiveServlet/showImage/2-149416-2532/bar_anim.gif
