Simple 2D plot help
  • August 10, 2010
  • 15 replies
  • 8675 views
I am trying to create a simple 2D plot which shows the distance to pre-defined coordinates from origin. I can successfully plot the required data but have to manually input each vector element of Y & X for the lines indicating the distance from origin.
Can anyone suggest changing the method of plotting so this is done automatically?
The symbols in the graph update when additional elements are added to the input vectors, but the lines indicating the distance from the origin have to be manually inputted.
Cheers
Mike
Best answer by RichardJ
You need a matrix with one column for each line. Rather than creating two matrices for X and Y you can create one matrix with real and imaginary parts.
RichardJ19-TanzaniteAnswer
Cheers Richard,
I know I said simple, but that was an almost instantaneous reply.
Mike
I draw lines that way all the time. It's one of those tricks that's obvious, but only after you have been told how to do it 🙂
Mike
Trying to understand your very original demand " all from origin & automatic"
Here is "all from origin" and automatic if you have those vectors from calculations.
If the vectors aren't from previously calculated, you will have to enter manually.
Jean
Cheers Jean,
Another good example.
Mike
