Skipping a non-converged trial
Situation: I'm calling a solve block (prime 4.0) multiple times for a variety of conditions.  Unfortunately, some of those calls don't converge, so I get no results.  I understand why it doesn't converge for some cases and that's not a big deal - if I can just get mathcad to move onto the next step.  So, what's a good approach for this?  I didn't have any luck using TRY since a failure to converge apparently isn't an error.
General question - so no examples attached.  But here's a simple hypothetical - solving for flow conditions along a pipe.  Each call would be at a different location along the pipe length.  If 10% don't converge I can still see the trend of parameters, so I'm happy to just ignore those failed cases.
Just looking for some ideas to try.
Thanks.
Edit - After further trials I did get TRY to work.  But still wondering if there isn't a better solution.  (It appears to have a bug if I add too many lines of code within the try, but that's another story.)
23-Emerald V
You can create a function of the result of a solve block. If you wrap that function into an on-error statement of an encapsulating function, you might (should?) be able to deal with error conditions where the solve block does not converge.
Please attach your Mathcad Prime worksheet with example to the message.
