Slider help
  • December 13, 2010
  • 25 replies
  • 16238 views
When you use a slider to represent a range of numbers is there a way to get the numbers to show up on the bottom of the slider; where the tick marks are?
D
Best answer by MikeArmstrong
I don't think it can be done automatically within Mathcad.
Mike
Mike
hrm.... ok
Thanks Mike
You might like the attached worksheet. It allows you to pre-define the Min, Max and Steps in the slider without going into the properties.
Mike
