solve an equation with iteration
  • January 27, 2013
  • 4 replies
  • 1928 views
Hi!!
I'm new to Mathcad and programming i general.
I have an equation that i want to solve iteratively, but i do not have the programming skills in Mathcad.
I think that a FOR-loop somehow will solve and give me the solution.
If anyone could help, it would be much appreciated.
Attaching the file with the equation.
Best answer by Werner_E
See if the attached helps.
The solutions depends upon whether you want to stop after a specific number of iterations or when a certain level of accuracy is achieved.
You were using the wrong sort of subscript - see attached.
Alan
Werner_E25-Diamond IAnswer
Ermis761-VisitorAuthor
Wow, Thank you very much!!! Thanks also for the small program which does the iteration.
/Evka
/Evka
You're welcome!
Werner
