Solving a function for a variable within a range
- October 6, 2012
- 1 reply
- 859 views
I am new to using mathcad and am having problems creating a program that will solve for an output value for an input variable within a given range. Basically I have a function with an input angle between 0 and 360 degrees (1 degree increments) and I want to solve for an output angle at each given input angle.
The mathcad function that I am attempting to create uses the Newton-Raphson method to solve a non-linear equation for multiple input values.
I have attatched the mathcad file that I am working with. If you think you can help, please take a look at it and let me know what I am doing wrong.
alpha = input
phi = output
Maybe I could also do this using the built in root function. I tried playing around with that but had no luck. If you have any suggestions please let me know.
Thank you!!
