Solving for Intersections within a For Loop.
- 11 replies
- 4437 views
- Translate All
Hi MathCAD Community,
To start I will try and give some background to the problem:
I have imported some data points that represent two edge curves of a surface in Creo. Using Matricies I can rotate these data points by a given angle made up of Yaw and Pitch. I then project these rotated data points to the zero plane using a projection Matrix. Next I fit a function through the two sets of transformed data and using integrals I calculate the area between these curves.
Now that I have worked out how to do this by specifying the rotation angle I want to iterate through 180 degrees of rotation in Yaw and Pitch to find the orientation that provides the smallest area between the curves.
My problem is when I go to find the potential intersection points of the two curves (for defining integral limits) I use a solve block, which cannot be implemented within a for loop for iterating through angles...
If anyone could help me find a solution to this ASAP it would be greatly appreciated. I have attached my methodology for completing this without iterating through a For loop.
Dion
