Solving "layered" equations for a single variable
- October 10, 2013
- 9 replies
- 2834 views
I'll start off by saying I'm new to MathCAD, and I'm pretty sure this is just a matter of discovering the proper syntax.
I am trying to solve a fluid flow problem where the flow splits through two paths, of different lengths and diameters.
My process goes like this:
- define required dimensions, flow characteristics, and fluid properties
- calculate simple parameters
- guess one parameter (V2)
- solve for multiple parameters based on initial guess of V2
- satisfy a relationship between pressure drops by iterating on V2
The problem, I think, is that V2 shows up on multiple "levels" in my pressure drop equations.
If Pd2 is a function of V2, and a function of f2
and f2 is a function of R2
and R2 is a function of V2
How do I write this out? Pd2(V2,f2(R2(V2))):= ...
Do I have to spell out the whole chain every time I refer to f2?
Do insead have to replace f2 in my Pd2 equation with an expression that is only in terms of V2?
I attached the file for an easier read. Currently it doesn't tell me there is an error, which bugs me.
