Solving multiple equations to derive transfer function
  • February 2, 2011
  • 12 replies
  • 8017 views
I am trying to solve a system of equations that i derived from nodal analysis of a circuit but i am having trouble figuring out how to get mathcad to symbolicly solve the system. If someone could tell me what i am doing wrong it would be great.
Thanks.
Best answer by MikeArmstrong
Solution found see attached, but not sure on the validity of the results.
Mike
http://communities.ptc.com/servlet/JiveServlet/showImage/2-149416-2532/bar_anim.gif
You have three equations and two unknowns. You need the same number of equations as unknowns.
Mike
A solution. Pick two different equations, and you will get a different solution because the equations are not consistent.
If the solution is valid then the third equaton isn't
Valyence1-VisitorAuthor
Yes thank you I added one extra node in my analysis that i didn't need thank you for the Help!
