Solving Simultaneous Equations Repeatedly using Different Constants
  • May 1, 2014
  • 3 replies
  • 1470 views
Problem I have is that I am solving for 12 variables using Simultaneous Equations. This I have done. However, now I want to change one of the constants (theta) several times to specific values and solve the Simultaneous Equations for each value of theta. I have tried to give the initial values of the variables several values in matrix format along with the several values of the constant and this did not work. I also tried to give the inital values of the variables with respect to the constant along with the several values of the constant and this also did not work. Attached is file without multiple values of theta since I couldn't get it to work.
Help Please
Steve T.
Best answer by Fred_Kohlhepp
You can turn a solve block into a function:
You can solve the system of equations in a parameterized form with theta as the parameter. Go to the Quicksheet in the help file. The navigation is shown below.
23-Emerald I
May 1, 2014
Fred,
Perfect.
Thanks a bunch! Great help.
Steve T.
