Specific Units in the equations
Good morning,
Does anyone know if I can specify the units on equations?
For example, when I want use some empirical correlations; the expression uses a formula that only works with the correct set of units. In MathCad, when I use the formula, the program uses the units of the Base System, but if only for that expression I want to use, for example, °F instead of K, it is possible?
Oscar J.
