Spring damper - resonance, forcing, second order ODEs
  • October 9, 2010
  • 4 replies
  • 4291 views
Can anyone point me in the direction of a worksheet that may be used in teaching engineering students the standard topic of second order ODEs using a mass, spring, damper system? version14 Many thanks
In quicksheets check the point
Engineering Applications: Damped Harmonic Oscillation
in calculus and de.
Regards. Alvaro.
Issy1-VisitorAuthor
Thanks for pointing this out, Alvaro. I was thinking of something a bit more extensive involving solving the ODE analytically and investigating the transient and steady state elements of the solution including resonance.
With regards,
Ian
Ian,
These files might help, I did them 4 or 5 years ago. You will probable want to manipulate a litte.
Wayne
