stacking range value of matrices
- August 20, 2011
- 6 replies
- 3104 views
hello, I am new to mathcad programming. I am trying to create a program which has te following input: a function and matrix made of a variable number of rows and a column (a vector). The solution of the function for every element of the vector is a vector. I am trying to make a program which will stack the results for every value of the function, with the argument take from the vector.
To better understand what I am trying I attached the file.
Thank you.
