surface plot of matrix of vectors
  • October 25, 2010
  • 17 replies
  • 6984 views
Hello Everyone.
I have a matrix of vectors. i need to simplify it as matrix only.
First i want to zero all negative values
Then surface/contour plot it. It won't plot as it stands.
Thank you in advance
File attached
Best answer by StuartBruff
and here's another way ...
Something like the attached?
To simplify the function I have used a few predefined functions within the program.
Mike
23-Emerald V
October 25, 2010
can you explain what you did to It. it's displayed correctly but i can't see how?
btw the way to remove negative values from a matrix in just one sweep was awesome. I didn't know you could do that.
is there a way to show non integers in the x or y axis or does it always have to be integers. one of the axis is months. so thats fine. but the other is hours,
-3.5h, -1.5h, -0.5h, 0.5h, 1.5h, 3.5h etc
23-Emerald V
October 25, 2010
I've annotated the worksheet and reposted it. You don't have to use integers for the x and y axes. I've given a rough example in the attached worksheet. Essentially, you group 3 matrices together, one for each of the x,y &z values of each point you want to plot. Generally, for this type of work, the X matrix consists of columns of the same values and the Y matrix of rows of the same values. Bear in mind that they are co-ordinates for each point, so using your value vector as is (6.5, 5.5 .. 4.5, 5.5) will create 2 y,z values for each duplicated x value.
