Swap between lbf and lbm
If something weighs 10 pounds, I put M=10*lbm
The inertial load factor is LF=100gs (100 gees)
The force will be M*LF= 10*100=1000lbf
Why does MC screw up the units? I remember, if I used M*LF*g  then it used to revert to lbf. It does not do so today.
What is the best way to do this
Please clarify your problem.  Uploading your file and/or screenshots would be helpful.
Here is what I get:
jdesai-21-VisitorAuthor
Never mind Fred. I just need a strong cup of coffee. It works now. Thanks
BTW. Do you need the * when you type in the units manually. I noticed you don't. Do you insert the units with a keyboard stroke or do you pull down and mouse it in from the pull down menu.
23-Emerald I
You can type most units; may need "cntrl-Q" twice to get the labels right.  (is it a variable, a unit, a constant, a . . .)
23-Emerald I
Not sure what your problem is.  In Prime 3.0:
When I was at school, I learned that weight (not mass) should not be measured in grams, but in newtons (SI). We went to the store and asked the saleswoman to weigh 5 newtons of sausage!
Hmmm. Did Newton get hit in the head with a sausage? I thought it was an apple:)
