switched return
  • May 18, 2011
  • 3 replies
  • 2359 views
before running to deep into the obvious wrong error message, allow me to ask wether is possible with mathcad 14:
if condition ==true
return vector of elements divided by their different units
else
return another vector with another size and other orininal units (also divided by them removing them)
thanks
gerfried
23-Emerald V
May 18, 2011
if condition ==true
else
thanks
gerfried
Yes ... provided I've understood the question. See attached for an example.
Stuart
23-Emerald I
May 18, 2011
if condition ==true
else
thanks
gerfried
Before you get too far into this, look up the UnitsOf() function. While it can (and has) caused much anguish and many errors, x/(UnitsOf(x) will render a quantity that has no units and is numerically the correct value of x expressed in default units. Keeping track of what the units SHOULD be will still be problematic.
Can you provide a worksheet indicating what your after, will save people guessing.
Mike
