Symbolic Derivative Problem
  • February 10, 2013
  • 17 replies
  • 4168 views
Please see the attached worksheet.
I need the actual derivative of vf(lambda,alpha) function. MathCad says it is too long to be shown.
Is there any way to overcome this issue?
Thank you so much.
Anousheh
Best answer by Werner_E
Where? I couldn't find that problem in you worksheet. Obviously I'm missing the point. Always better to post a stripped down worksheets which just shows the error or, as in your case, the undesired behaviour.
As you have defined Alpha at the top I assume you are interested in the derivative wrt lamda. I move the range variable for lamda down a bit.
One way to look at an expression which Mathcad 15 says being to long is to convert the worksheet in Prime format and load it in Prime 2, if you have the possibility to do so. Prime would let you scroll - no, unfortunately not, but you are allowed to enlarge the expression region to the right.
Werner_E25-Diamond IAnswer
Anousheh1-VisitorAuthor
Hello Werner,
Thank you so much for your time and great help.
I do my best to follow your points.
Thanks again and regards,
Anousheh
