Symbolic trignometric functions
  • June 16, 2011
  • 8 replies
  • 4789 views
How to tell the symbolic processor that n is an integer so while evaluating
cos((n+.5)* pi)==>0
and sin((n+.5)*pi)==>1
is there a way to force the symbolic process to do that once it sees these expressions it will just replace them with 0 or 1
The reason I am not using n as integer range is: this is part of a long calculation/derivation
Best answer by RichardJ
Add a "simplify"
cos((n+.5)* pi)==>0
You might want to think more carefully about the values you've suggested for the cosines and sines! However, try using both the 'assume integer=n' and 'simplify' symbolic qualifiers.
Alan
ChadG.1-VisitorAuthor
Thanks Alan I did not know about that "how to use the qualifiers assume n=integer?"
You think there is something wrong mathematically!
Well, cos((n+5)*pi) is -(-1)^n when n is an integer and sin((n+5)*pi) is 0.
Alan
