System of ODEs
  • March 19, 2013
  • 15 replies
  • 5593 views
I came across this sytem of ODEs on a Differential Equations primer website, and am wondering if there is a way to model it in MathCAD (15)?
Thanks!
Best answer by Fred_Kohlhepp
As Harvey says, not a system, two seperate equations.
That is not a system of equations. They are independent of each other. You can solve each equation independently using Mathcad's ODE solvers.
Good point, Harvey. This is not a system of equations. My terminology has gotten a little rusty over the years...
What I am having trouble with is determining (with MathCAD) the value of tm (which is known to be 35.475). Any advice?
So it looks like you want to find the value of t where Q1 = 500? And then you solve the next equation for Q2 starting at that time, tm?
23-Emerald I
March 19, 2013
You make it look too easy. Thanks! Your point is noted regarding the terminology.
The Laplace method worked, but it required one manual cut and paste to obtain the transformed equation, so it wasn't totally automated.
