Tank Heating an Oil Stream under PID Control
- November 18, 2013
- 0 replies
- 2084 views
Description:
A cold oil stream is being heated in a stirred tank. The dynamic change in temperature in the tank is modelled by an ordinary differential equation. The temperature of the liquid in the tank is driven to a set point via a PID controller, which alters the heat added to the system.
