The movement of the body around the mass problem!
  • January 5, 2013
  • 14 replies
  • 6259 views
hi
I found a book in the movement of the planets around the masses. Rewrote all of the books but does not want to work. I would also like to make this move planets with animate to.
Best answer by ptc-286210
Please, find Odesolve command in your sheet. You wrote vector as x,y,x, but it must be x,y,z.
See attached.
Changed parameter in Create Space and type of graph from surface to scatter.
Look what happens if you change the interval in odesolve (from 1 to3 or greater)
Thanks to rosenm for finding the typo.
jkowalski1-VisitorAuthor
How animate movments?
A description, esp. the meaning of your vars and functions wouls have been helpful.
Is F(t) a vector describung the position of moving a fifth planet (with mass 0???)
Does the attched help?
BTW, Freemake Video Converter did the job well. THnaks again.
