Trouble with a fortran loop and getting it into mathcad
  • April 9, 2013
  • 2 replies
  • 1935 views
Hi guys
I have to admit upfront I am new when it comes to programming. I am having trouble getting the following fortran do loop converted over into mathcad. It looks like the program is running through and getting initial results and then taking those to use for the next iteration and so forth...like a cumulative sum. Seems like it shouldn't be all that hard but I can't get things to initiate correctly. Can anybody get me back on track?
Best answer by Werner_E
See if the attached fulfills your needs.
Should mention that I didn't check the formulas.
Werner_E25-Diamond IAnswer
msu121811-VisitorAuthor
Werner,
Thank you very much. That is it. I have spun my wheels for days on this subject. Knew you guys on here can always help me out.
Thanks again,
Addison
