Trying to duplicate a formula
- April 26, 2014
- 6 replies
- 2612 views
Hello guys,
In me previous discussion I was trying to set-up my own equation.
It worked out eventually thanks to you guys.
But, I have been dealing with an other problem.
I have been trying to duplicate a formula from the beginning till the end.
I have found the original formula on some forum on the internet.
The formula seems correct because the same formula is written in roarks' book.
I have been trying to prove the formula with the use of mathcad and the weird (in my opinion) statements on the engineerings forum.
Can you please help me towards the correct direction?
It is about the deflection of a thin ring under a point load.
Here is a quote from the forum regarding the formula: "You do this with the energy application using Castigliano which is far easier than curved beam theory. You first split the the ring in quarters using the second quadrant assuming the force is north south. If the load is north P, then you have a built in edge on the north point and a moment M1, undetermined and a south vertical force of P/2 at the west position. You write the energy integral M^2/2EI*rd@ over the 90 degrees where M=m1-(P/2)r(1-cos@)The partial derivative with respect to M1 would be the slope at the west position is zero due to symmetry and the partial with respect to P is the vertical displacement, your problem. After all this I get
y=Pr^3(pi/4-2/pi)/EI"
Tim van Lunteren
