Mike's symbolic calculation approach will work sometimes, but only if the symbolic solver can find a solution. That is far from guaranteed. Here's an old thread on the issue:
How come ? hover on your text and is all shows as link ?
Your problem is not of defining or re-defining, no. Your problem is to properly select, thus assigning. You can ignore my suggestion or require more help, but for more help you would have to "save as 11" just to view a bit more for a more general construct.
