Unit issue in solve block
- 6 replies
- 2389 views
- Translate All
I have tried to solve equations of current ramping up and down in a power converter, including the series (parasitic) resistances in the circuit. Solve block works fine and finds sensible results, except ... one of the 2 parameters I am searching (aa) is a duty cycle, and therefore, should be unitless, and it comes out of the solve block with a unit (Amps, like the other variable). I just can't find what I've got wrong, since all the equations I input will only work if the variable is unitless, so why on earth would the solve block add a unit that doesn't work ? Unless I missed something ...
