use of hyperbolic function coth(x) inside a programming loop
  • June 28, 2012
  • 1475 views
i have been trying to use coth(x) inside a programming loop and i have an error saying "this function refers to itself inconsistently"
but, when i change the coth(x) just for x, the loop runs ok.
Please, see pdf file with the loop attached.
regards,
Rogelio
Please, disregard this question.
i found the problem.
i had problems with the units that i was using in the loop.
it is now working fine.
thanks anyways.
rogelio
