v15 build
  • January 21, 2011
  • 8 replies
  • 5323 views
Can someone please remind me how to figure out what "M" build I have? Going to HELP | ABOUT I see "Mathcad 15.0 (15.0.0.436 ..." How would I know if this is build "M005"?
Presotn
Best answer by FDS
Preston, if you have M005 you should see: Mathcad 15.0 (M005 [MC15_M005_20101105])
FDS13-AquamarineAnswer
Check you check if the attached yields the correct version.
Mike
Doesn't seem to work for me; it reports "14.1.0.457." Unless that's what v15 M0005 really is ...
I have the same version as you and get the same results. Maybe someone with a earlier version will try and see if it works.
Or maybe the function doesn't work with M15.
Mike
