variational method
  • September 28, 2013
  • 3971 views
hello,
i want to do the variational method by math cad, is it possible?. variational method is an one of the apporaximation method to calculate the ground state energy of a particle in any system. pls help me
aayyappan1-VisitorAuthor
Thank you for your response,
I didn't use mathcad, so I don't know about it. can you tell how to create the worksheet for this variational method. what are the information should be include in the worksheet. pls explain...
Again a very unspecific question.
What have you done so far to get acquainted with the software?
You may start with the documentation you got, use a decent primer or get your hands on the help sheets which are installed along with the software. The help is also available online here http://www.ptc.com/cs/help/mathcad_hc/prime2_hc/
